Which cooler is better? Cooler Master Hyper 212 EVO - or a Cooler Master Hyper 612 Ver.2.
museprime
443
My build is a Bitfenix prodigy case with an my CPU i5 . I'd like to replace the the stock fan with one the following cooler fans.
I am looking for something that will keep that CPU cool and a is quiet. I just installed a new GPU been playing witcher and I notice my fan is loud and I just wanna keep the cores between 55 & 70 or ideally as low as possible. And of course quiet as can be.
Also would anyone know a good PSU- that modular? The one I have is good but it hardwired and like to get my cable management looking better
Here are my specs
Prodigy bitfenix case
Asus P8H77-I Mini itx Motherboard
Intel Core i5-3570K Ivy Bridge
GTX 970k
Yes! Take a look at this one. Check case clearances just to be sure.
http://www.newegg.com/Product/Product.aspx?Item=9SIA4UF2DZ6565
Cool is there any other cooler that you might think would be better for a build like this?
