Which cooling system would be best for my rig?
DR_N00B
Hello, first I would like to apologize if this is in the wrong section. :p I am building a pc (my first gaming rig) and I'm having trouble as to which type of cooling I should get. I'm getting my computer from cyber power, and they only have limited options on the coolers.
Cyber power's cooling options:
-LIQUID COOLING
-Asetek 510LC 120MM Radiator & Fan
-Asetek 550LC Dual Standard 120MM Fans (push/pull)
-Corsair Hydro Series H60 120MM Radiator & Fan
-Asetek 570LX Liquid Cooling system w/ 240MM Radiator and Dual Fans
-FANS
-Thermaltake Frio OCK (though I was reading that this one blocks off 1-2 ram slots depending on your mobo.
-CoolerMaster Hyper 212 evo
I have no idea as to which cooler I should pick. :(
I appreciate all of the help. :bounce:
Pieter_27
27
Okay so i Got a gigabyte gtx 460 se.I already overclocked it to 820 mhz no problem. my current temps are 30 c to 38 in game i was aiming for about 930 mhz I NEED YOU HELP IM NEW TO OVERCLOCKING!!!
cmi86
You need to create a post in the overclocking forum to recieve proper assistance.
