Which corsair power supply series is the best?
Chris L
28
I'm planning to buy a 750W corsair power supply for my PC but I don't know the differences between the series (AX, HX, RM, CS etc) or which one would work best with my PC. Any help is appreciated.
My Specs are:
- Intel Core I5 3570K 3.4Ghz CPU Socket 1155 6mb Cache Ivy Bridge HD Graphics
- Corsair Vengenace 16gb ( 2x 8gb ) DDR3 1600mhz Memory
- Asus P8H61-MX USB3 Socket 1155 H61 USB 3.0 Onboard Graphics* Motherboard
- Seagate 1tb Barracuda 7200rpm Serial 3.5" Sata Hard Drive 64mb
- Samsung 24x DVD Writer Dual Layer Black
- Standard Intel CPU Heatsink and Fan
- Tenda W322P Wireless PCI Network Card 300Mbps
- I'm also planning to get an Asus GTX 770 2GB DDR5 to replace my current graphics card
For your build if you don't plan to SLI the 770 this PSU is more than enough with all your system overclocked CORSAIR Enthusiast Series TX650M 650W http://www.newegg.com/Product/Product.aspx?Item=N82E16817139031
If you want a 750 w then this CORSAIR Enthusiast Series TX750M 750W http://www.newegg.com/Product/Product.aspx?Item=N82E16817139030
Seasonic is one of the best PSU manufacturer.Maybe you want to look at theese.
SeaSonic M12II 650 650W 80 PLUS BRONZE Certified Modular http://www.newegg.com/Product/Product.aspx?Item=N82E16817151106
SeaSonic M12II 750 750W 80 PLUS BRONZE Certified Modular http://www.newegg.com/Product/Product.aspx?Item=N82E16817151107
