Which CPU air cooler would be better? According to availability
magnus_m6
16
Hi, I have the following options
- Cooler Master Hyper T2 (RR-HT2-28PK-R1
-Thermaltake Frio Silent 14
-Thermaltake Frio Silent 12
-CPU GammaXX 200
-CPU GammaXX 400
PD: CPU i7 6700K (I'm not planning to do hard overclock, I choose this CPU for extra speed: 4GHZ)
Case: NZXT Noctis H450
GPU: GTX 1060 MSI 6GB
Thank you in advance.
as you have a very big case you are not limited by the width of it.. so the best are Thermaltake Frio Silent 14 and CPU GammaXX 400. thermaltake is quieter and draws less power. Deepcool is a bit biger and maybe a little cooler, but its not really a big difference since its not under a heavy load.. both coolers are designed for a lot more
I would go for the cheapest, or the Deepcool. LED will look great through your case window!! 😉
