Which Cpu cooler will fit my Xigmatek asgard pro case?
Mar 18, 2018
4
I need to replace my cm tx3 evo cooler but it seem there are many choices so i look into noctua nh d14 and cryorig h5 universal for my I5 3470 but i just don't know how to make sure it fit my xigmatek asgard pro? Any help will be appreciate.
May i ask some,my rig is i5 3470,asrock h77 pro4mvp, Galaxy Gtx 660 ti,2x4gb gskill ddr3 ram. While playing Attila total war i exprienced lag during battle and blood on. So i look to upgrade to i5 8400 but then i realized i also need new mobo and ram,that'll be out of my budget. If just get new gpu like 1060 3/6gb or rx480 will Attila be running good? Sorry for long question.
Edit:My cpu is I5 3470 not 3570, typo
The h7 isn't older, it's merely a litle smaller (120×mm as opposed to 140mm) for people with more compact cases.
The h7 is way more than enough for a sub 100w i5.
As I said the gammaxx 300 will handle that gpu & it's generally a $20 cooler.
Case syates 160mm max , both those coolers are 160mm exactly.
I think you may be pushing it , they may fit ,they may not.
Anyway for a 3570 theyre both massive overkill.
A decent 120mm tower is more than enough.
Cryorig h7 or deepcool gammaxx 400.
I ran a 3570 with the cheaper gammaxx 300 & at the lowest fan rpm it still never touched 65c under stress testing
My cpu is 3470 not 3570 sorry for typo. I noticed cryorig h7 is old model and quite popular but i want great cooler if it fit. By your answer it will not be perfectly fit.
Wow i never thought it will be overkill as bigger is better right.
Attilla I would say is very dependant on cpu power.
While the 3470 is a decent cpu its some 6 years old.
Drop the In game resolution to 720p (assuming your current res is 1080p?)
If you get a performance Boost then yes a gpu upgrade will help
If performance remains roughly the same you're cpu limited.
