which cpu is best for light gaming using integerated graphics only
yimcooldude
19
I am from india.
I want to chose a cpu having integerated graphics that can be used for some light gaming.
I am not installing any discrete graphic card in it.
The processor should not cost more than 4000Rs. Please reply with the model number of the cpu, it can be from intel as well as amd, but the purpose should be served.
How about intel pentium g2020?
This depends on how light you mean by your gaming. Simple online flash games, you can use a cheap CPU with. You may be able to even play some older games like Diablo, Half-Life pretty well.
List a few games you are talking about then you can see if you can play any of them on a slower CPU. To get a half-way decent gaming with integrated video you need about an A8-A10 AMD CPU which start at close to double your budget.
You may want to look at used systems.
