Which CPU will work with my Motherboard?
LiquidHardware
24
I really need help here guys and I will try to be short!!! I have been planning on buying a new CPU for my computer for a while so that my gaming experience can be better like for MMORPG and FPS online games while avoid having to buy a new motherboard. My mother board is currently a Hewlett Packard Model 0B4Ch/ Intel X58 express/ LGA1366. I have been doing my research and shopping and I found some i7 4-core LGA1366 but I want to be sure that it will be compatible. What other specifications and information do I need in order to know which CPU would work correctly for my Mobo? Thank you so much if you took the time and consideration to help me out, I really appreciate it because this has been driving me crazy!!!
Current Rig:
HP Z400 Workstation(lowest end model)
6ram
EVGA GTX 760 (replacement/upgrade/Obviously not originally from PC)
Intel Xeon W3503
Other Helpful links and Info:
http://www.findlaptopdriver.com/specs-0b4ch-hewlett-pac... (MotherBoard specs)
http://h18000.www1.hp.com/products/quickspecs/13276_na/... (My pc's specs)
Some CPU's That I took a liking to:
http://www.overclock.net/products/intel-core-i7-process...
http://www.ebay.com/itm/221380519374?_trksid=p2055119.m...
http://www.ebay.com/itm/271407540057?_trksid=p2055119.m...
http://www.ebay.com/itm/291063673176?_trksid=p2055119.m...
(On a Tight Budget of $200 at most)
http://www.cpu-world.com/Sockets/Socket%201366%20(LGA1366).html
Here is a list of supported cpu's for 1366 socket. The choice is limited because lga1336 is discontinued and was originally intended for high end i7, xenon cpu's only. So the list is small. Hope this helps.
Hmmm it says "page is not found" But if all your saying is that i just need the LGA1366 socket CPU, like some of the i7 I found, would work then that's all I need! Thanks bro!
