Give the BIOS update a miss unless & until you specifically need to do it (ie to fix a problem or for a CPU upgrade further down the road0.
Reason for that advice is that performing a BIOS update isn't like a simple driver install --- it has the potential to cause you real grief if the update process goes wrong.
