Which ethernet cable is best?
newpcgaming
107
this is my motherboard:
ASUS Z97-A LGA 1150 Intel Z97 HDMI SATA 6Gb/s USB 3.0 ATX Intel Motherboard
I'm building a gaming PC and was wondering which Ethernet cable would best suit the MoBo, thanks.
any CAT5e or CAT6 cable will work fine, both are rate to support 1000Mb/s.
the cable will not make any difference in gaming speed
I honestly do not think it matters as long as it's cat 5 (or cat 6 if you want to research it.)
Well from what I've read, cat5e can run gigabit speeds, but cat 6 is certified. Other than that, there isn't much of a difference right now. They are both extremely cheap anyway so might as well grab the best cat5e you can find.
