Which Ethernet Cable?
All CAT5e and CAT6 cables will have the same speed and durability if you don't acutely bend them. They will both provide gigabit connections if the devices on the rest of the components are gigabit capable.
Those cables are pretty much identical. I would buy the less expensive, as they will both perform equally well.
Thanks
