Which fan configuration will deliver better airflow?
chibamarco
188
Hello everyone, I have an question.
I will get an Fractal Design Define Mini C for my first build, but I'm concerned about the airflow.
Here are my fan configuration ideas:
1: 4x NZXT Aer P
Two of them will be used for front intake.
Two of them will be used for top exhaust.
2: 2x Noctua NF-A14 industrialPPC-3000 PWM
Option 1:
One of them will be used for front intake.
One of them will be used for top exhaust.
Option 2:
Both will be used for front intake.
Stock front fan will be used for top exhaust.
Which config has the best airflow?
Thanks in advance. :)
I'd choose 1, with the NZXT AER fans. You're forgetting a critical element in your airflow, which is the rear exhaust. I'd ask you to keep all the fans the same, meaning 5 NZXT fans with the top and rear being in exhaust and the front 2 set up as intake.
