which gpu is best for my build? help guys...!
Arpit Maratha
6
Hey....guys..
I just wanna know which gpu would be great for my build to play games like battlefield 4...titanfall and some other high end games of 2014-2015 at high-med graphics...! ( mostly high at 1080 res 😀)
My Build :-
Cpu :- Intel Core i5-4440 3.1GHz Quad-Core Processor
Ram :- G.Skill Ripjaws Series 8GB (2 x 4GB) DDR3-1600 Memory
Motherboard :- ASRock H81M-HDS Micro ATX LGA1150 Motherboard
Power supply :- EVGA 600B 600W 80+ Bronze Certified ATX Power Supply
Storage :- Western Digital Caviar Blue 1TB 3.5" 7200RPM Internal Hard Drive
Any suggestions on my build would be apreciated thnx in advance!
I would say a r9 280 would be your best bet. You can get them around $200 easily right now. If you would rather an Nvidia card, the GTX760 should do. If you want more muscle then look at a r9 280x or a GTX770. The r9 280x is roughly about the same in performance(varies from game to game), and is cheaper than the GTX770. Usually around $50 cheaper with deals, maybe more. :)
thnx for it..........! going for r9 280x!! 😀
