Question Which gpu should i choose between RX 6750XT and RTX 3060 Ti 8GB
Personally I’d get the 6750. It’s a bit closer to the 3070 and the extra vram should help it stay relevant longer.
The 3060ti will be better for ray tracing if you care about that but when you look at screen shots it can be hard to tell on some games. Both are the outgoing generation so personally I’d go with the card with a bit more raw power. Just my 2 cents.
