[SOLVED] Which GPU Will Work Better for My PC?
incmachine
Commendable
Oct 14, 2021
49
Which GPU will give this PC the highest performance levels and the lowest potential for bottle-necking?
I have an AMD Athlon X4 950 3.5GHz Socket AM4 Processor and it does not have integrated graphics, so I am trying to figure out which GPU would be most appropriate in terms of compatibility.
I have AMD Radeon HD 7470 GPU - 1GB GDDR5 - DVI + DP - Full height bracket and a MSI GeForce GT 730 Fermi DDR3 4GB DirectX 12 (N730-4GD3V2).
Other details:
The motherboard being used is a Gigabyte GA-A320M-S2H and the RAM is Neo Forza FAYE 16GB (2x8GB) 288-Pin DDR4 3200 MHz (PC4 25600) SDRAM Model NMUD480E82-3200DG20
Other details:
Zerk2012
Ambassador
Other details:
https://gpu.userbenchmark.com/Compare/Nvidia-GeForce-GT-730-vs-AMD-HD-7470/m12582vsm8681
Reactions: incmachine
logainofhades
Other details:
What is your budget? You could possibly get more performance, per dollar, upgrading to a Ryzen APU. What is the make/model of your power supply?
