Which graphic card will be suitable for hp dc7600 ultra slim desktop
Siddharth Chandra
6
I need help!!!!!!!plz tell me which low profile graphic card would be suitable for my pc that will fit in my cpu and run games at medium settings!!!!!!!!!!!
I would apreciate your help!!!!!!!
plz!!!!!help
and nvidia 8600gt 512mb will fit in my low profile pc1 x16 slot or not!!!!!!!!!!!!!
Freakykiwi
76
Sorry - the Ultra Slim model does not support a discrete graphics card. Check the specs at the link below - all you get with this model is a PCI slot.
http://h18000.www1.hp.com/products/quickspecs/12253_ca/12253_ca.HTML
hmm, according to the manual that freakykiwi gave us, your ultra slim model isn't support PCIE slot. BUT, if you sure it support (you've said it has low profile) then you can use low profile card like these:
http://www.newegg.com/Product/ProductList.aspx?Submit=ENE&N=100007709+600038363&QksAutoSuggestion=&ShowDeactivatedMark=False&Configurator=&IsNodeId=1&Subcategory=48&description=&hisInDesc=&Ntk=&CFG=&SpeTabStoreType=&AdvancedSearch=1&srchInDesc=
But with only 200W PSU, I'm not sure you are "safe" to add another component inside that slim PC...
