Which graphic card will work with my motherboard?
simran178
My CPU Is AMD A10-7800
Motherboard:
Motherboard
Manufacturer ASUSTeK COMPUTER INC.
Model D415MT_BM2DK (FM2+ )
Version Rev X.0x
Chipset Vendor AMD
Chipset Model K15 IMC
Chipset Revision 00
Southbridge Vendor AMD
Southbridge Model A78 FCH
Southbridge Revision 2.6
System Temperature 39 °C
BIOS
Brand American Megatrends Inc.
Version 0304
Date 2015-01-16
Voltage
CPU CORE 1.164 V
MEMORY CONTROLLER 1.332 V
VIN2 2.040 V
VIN3 1.980 V
VIN4 1.068 V
VIN5 2.232 V
VIN6 2.232 V
VIN7 1.680 V
PCI Data
Slot PCI-E
Slot Type PCI-E
Slot Usage Available
Bus Width 32 bit
Slot Designation PCIEX16_1
Characteristics 3.3V, Shared, PME
Slot Number 0
Slot PCI-E
Slot Type PCI-E
Bus Width 32 bit
Slot Designation PCIEX1_1
Slot Number 1
Slot PCI
Slot Type PCI
Bus Width 32 bit
Slot Designation PCI1
Slot Number 2
Power Supplies for that PC are listed as:
Power Supply
250W
350W
350W (80 PLUS) (Optional)
500W (Optional)
500W (80 PLUS) (Optional)
You should open up the PC and check the label on the power supply. A GeForce GTX 1050ti requires 300 watts or greater. The GeForce GTX 1060 requires 400 watts or greater.
1 x PCI-e 3.0 x 16 (got it from: https://www.asus.com/us/Tower-PCs/D415MT/specifications/)
any GPU can fit that motherboard...
the real question is, does your PSU and case size can support it?
with that CPU, i would opt for either 1050ti (if ur PSU has low wattage) / 1060 3GB (if ur PSU had enough wattage + the price is good)
Power Supply
250W
350W
500W (Optional)
