which is best cabinet for me.
Tony driftking
102
Hi i am planning to buy a gaming case between these two corsair graphite 780t and 600t. which one is best for airflow and to support future hardwares. So please suggest me the best one especially for best airflow. I am using intel core i7 2600 and a motherboard by intel-dh61wwb3. a graphics card from asus gtx660 dc2 oc edition 2gb ddr5. 2x4gb ddr3 1333mhz ram. I am not interested in liquid cooling and sli for multi gpu. I am heavily confused. Please inform me quick.
I mean is there will be any significant changes will takes place in temperature and performance of my cpu gpu and ram, motherboards and will it effect bad on my components if my cabinet will have or not have(side panel without having way to enter air inside) side panel fans? can i use atx or e-atx or xl-atx motherboard in 600t Please do it quick its very urgent.
And if i am enable to use e-atx or xl-atx motherboard in 600t then will it effect good or bad in performance and temperature of my components as per conditions of case having or not having side panel fans?
