Which is best? manual or mobo cpu fan spead control?
jeanluclariviere
127
From my experience - I've always used controllers for case fans, but haven't got a CPU controller. I find the advantage of having controllers is the linear approach the coolers/fans take - (ie: low, medium, high speeds) It provides a stable platform which is more predictable and consistant than the auto feature, though, I would think that with the controller comes a bit more power consumption. It's also more hassle, if you'd rather just play it safe.
50bmg
903
Which would give better cooling results under load?
would the mobo controls run the HS fan at its highest while the cpu is under load?
