Which is better? 2gb of gddr5 128bit or 1gb of gddr5 256bit?
DaanDieKooHaan
18
For example the Sapphire Radeon HD 5850 1GB Vapor-X vs MSI R7 260 2GB OC.
I have heard talk that the bus width doesn't even matter anymore, but can't think that that's true?
If you can explain fully please do.
Thanks in advance!
It varies on a case-by-case basis.
Newer GPU architectures tend to be more memory-bandwidth-efficient so you can get about the same performance with half the memory bus width. Nvidia's Maxwell does quite well there.
If you compare the HD5870 against the R7-260X (one notch above the HD5850 and R7-260 you were looking at), you can see they are fairly close in performance, with the R7-260X leading most of the time
http://www.anandtech.com/bench/product/1062?vs=1044
