[SOLVED] Which is better? B450M Tomahawk Max or Gaming Plus Max
Apr 28, 2020
5
Which do you think will be better, accounting for the price difference between the two boards for Ryzen 5 3600? I am super confused between both. I really don't find anything much in specs to determine why Tomahawk is so popular, and the other one not so much. Am I missing out on something?
I intend to add another GPU later, but won't be using SLI, just for running programs. In the product page, it says Tomahawk Max has Multi-GPU support while Gaming Plus Max does not(not sure why, because both have 2 PCIEx16 slots). Any clarifications on this?
