Which is better for gamind and modiling
Samo1997
Commendable
Sep 29, 2016
6
I am confused between 2 laptops i want it to be good for gaming and modiling neutral for both ... Both are lenovo
1- lenovo ideapad 310-15
I7 6200u
8gb ram
Gefore gt 920mx 2gb
2 tera bytes
2-lenovo z51-70
I5 5200u (2.2ghz , 3M)
8gb ram
1tera
Ati r9 m375 4gb
Am on hurry please ... Which is better overall ... Thank you
GPU - The Radeon R9 375 is better than the GTX 920M. Processor wise - The Intel Core i7-6500U's clock speed is measured to be 9% faster than the Intel Core i5-6200U. In terms of cache/smart cache size, the Intel Core i7-6500U has 33% more than the Intel Core i5-6200U does, which means it can access more frequently used data.
So i5 6200u
940mx 4gb
6gb ram
Is better than the first two ?
As velo3100 said yes the GTX 940m is better than the R9 375.
Okay 6gb ram and 8gb ram will make a huge difference or it will be okay with gaming ? Thank you in advance
