[SOLVED] Which is more power consuming at Load R5 3600X or R7 3700x?
As Ryzen 3000 Chips are really power efficient I would like to know which one will consume more power while being at load?
They look to be about the same.
What's heavier, 100lbs in one hand or 100lbs in 2 hands. With a 100% cpu load, on both cpus, using the same test software, the differences will be elsewhere, such as time executed, amount of computations etc. There's nothing saying the actual internal voltages going to each core, and what's actually used by each core individually is identical.
