Which is the best cooler for my case?
joshmac313
8
Hey guys, I need some help here.
I was thinking of buying a h100i for my Aerocool X-Predator X3 Gaming Case but I have read in some reviews that this particular cooler will not fit.
I have a 3770k and I am wanting to over clock it to at least 4.3Ghz from the stock 3.5Ghz.
Which is the best cooling unit available for me??
Well the h100i certainly looks nice and gives good performance but I say you do not require it for overclocking to only 4.3 GHz. Also the sound that the H100i makes is very high (very). I suggest you go for a good old air cooler like the Noctua nh d15: http://www.ncixus.com/products/?usaffiliateid=1000031504&sku=96233&vpn=NH-D15&manufacture=Noctua&promoid=1469 $ 74.99
Or if you are deadset on a watercooler go...
Or if you are deadset on a watercooler go for the thermaltake water extreme: http://www.amazon.com/dp/B00DZL85XU/?tag=pcpapi-20
