which liquid cooling to choose (with my system info)
zeyads3
132
Hi, i'm about to choose a liquid cooling.
so my system.
cooler master scout case
corsair cx500 power supply
asus p8z77-v LX
asus gtx 650 ti
intel core i5 3470 (i don't need to overclock)
corsair vengeance (4x2) 8RAM ddr3 1600MHz
and i'm thinking to get a corsair hydro H60 liquid cooling, and is it good for my system or no need to get it?
leave your suggestions ^_^
Since you are not going to overclock you really don't need to use anything outside of the stock cooler. However if you are looking for a quiet cooling solution the Corsiar H60 is a good choice. I personally would get the Cooler Master Hyper 212 Evo and replace the stock fan with a quiet 120mm fan.
8350rocks
Yeah...if you're not going to OC...liquid cooling is expensive and unnecessary...save the money, buy a good fan cooling system for your CPU and spend the rest on a good case airflow fan or 2 for $8-10 ea.
Similar threads
