Which low end watercooling pump is best for me?
Flightsimluke
530
Hello,
The three pumps short listed are the Phobya DC12-260, the EK DCP 4.0 and the DDC1T.
Just a quick question really - out of the three, or any other pumps less than £45, which is better? Looking to run a 240mm Radiator, 16/11 tubing and compressions and an EK 7970 waterblock with Pastel Red Mayhems Coolant.
Important: Must be quieter and cooler than the Asus DirectCU cooler!
Regards
Luke
I will go for the EK DCP 4.0 pump. I will not recommend mayhems coolant or any other coolant than distilled water. Some say it can clog up the blocks, some say it doesn't, but the major guys here say it will. Use colored tubing for coloring effects.
