This is my MB configuration, which graphics card will best suit for my mb.
Chipset
Northbridge Intel P35/G33/G31 rev. 10
Southbridge Intel 82801GB (ICH7/R) rev. A1
Memory Type DDR2
Memory Size 2048 MBytes (buying another 2GB)
Channels Single
Memory Frequency 400.0 MHz (1:2)
CAS# latency (CL) 6.0
RAS# to CAS# delay (tRCD) 6
RAS# Precharge (tRP) 6
Cycle Time (tRAS) 18
Row Refresh Cycle Time (tRFC) 52
Command Rate (CR) 2T
MCHBAR I/O Base address 0x0FED14000
MCHBAR I/O Size 4096
Processors
Number of processors 1
Number of threads 2
Timers
ACPI timer 3.580 MHz
HPET timer 14.318 MHz
Perf timer 2.148 MHz
Sys timer 1.000 KHz
Processor 1 ID = 0
Number of cores 2 (max 2)
Number of threads 2 (max 2)
Name Intel Core 2 Duo E4500
Codename Conroe
Specification Intel(R) Core(TM)2 Duo CPU E4500 @ 2.20GHz
Package (platform ID) Socket 775 LGA (0x0)
CPUID 6.F.D
Extended CPUID 6.F
Core Stepping M0
Technology 65 nm
Core Speed 2200.1 MHz
Multiplier x FSB 11.0 x 200.0 MHz
Rated Bus speed 800.0 MHz
Stock frequency 2200 MHz
Instructions sets MMX, SSE, SSE2, SSE3, SSSE3, EM64T
L1 Data cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L1 Instruction cache 2 x 32 KBytes, 8-way set associative, 64-byte line size
L2 cache 2048 KBytes, 8-way set associative, 64-byte line size
FID/VID Control yes
FID range 6.0x - 11.0x
Max VID 1.325 V
Max CPUID level 0000000Ah
Max CPUID ext. level 80000008h
Cache descriptor Level 1, D, 32 KB, 1 thread(s)
Cache descriptor Level 1, I, 32 KB, 1 thread(s)
Cache descriptor Level 2, U, 2 MB, 2 thread(s)
Chipset
Memory Type DDR2
Channels Single
Processors
Number of threads 2
Timers
Sys timer 1.000 KHz
Processor 1 ID = 0
Codename Conroe
CPUID 6.F.D
Extended CPUID 6.F
Core Stepping M0
Technology 65 nm
FID/VID Control yes
Max VID 1.325 V
