I have been using HWmonitor for my new PC build and I do not know which temperature is correct. Also, are these temps good for a cryorig h7 on a fx 6300 after playing an hour of games?
I'd say the most important one is the MAX column. and 47 degrees max seems fine.
Oh I see, well, they each measure different things- the 75 degrees is the GPU, which is fine, the 47 degrees is the CPU which is fine, and the 34 degrees is the hard drive. The motherboard reading of 34 might be just a mirror of the hard drive, maybe not.
