Question Which monitor is better for everday use as a 2nd monitor?
Biggy Cent
80
So I upgraded to 1440p on my main monitor with an Asus.
My 2 old monitors are BenQ.
1st one is a BenQXL2420T - 120hz
2nd one is a BenQ GL2450-B - 60z
Which one should I keep as my 2nd monitor and which one should I sell? I believe the 2nd one is a new model but less refresh rate. I'm not very knowledgeable when it comes to displays and monitors.
Keep all 3 if possible? I've my primary on my GPU (GTX 1060), 2 and 3 on my CPU's (i7-4790K) GPU out of the mobo's VGA and DVI connectors. Primary for gaming, 2 and 3 for email, web browsing, system monitoring or any combination thereof.
Model for your new Asus monitor? I'd advise on keeping the 120Hz panel as your secondary but if all you is read articles and view regular content, the 60Hz panel will be more than fine.
That’s kinda of what I figured. I’m just gonna keep the 120hz. My Asus monitor is the 27inch TUF gaming 1440p monitor. I’m not home I forget the exact model.
Unfortunately I don’t have the room for 3. I don’t even think I would use 3 🥲
