Which monitor will be right for me?
MandyBoy
25
I am buying a rig with i7 3770k, 1 GTX 680 2GB(EVGA). I wanna play games like Battlefield 4, GTA V and games like them with max settings (Maybe 1920*1200). Which 24" monitor will suit me most?
If you havent already, I suggest reading the in-progress monitor guide stickied at the top of the forum.
So you want a 1080p, 24" monitor.
If you have the budget, going for something like a BenQ XL2420T will give you 120hz and 3D capability (if you buy the glasses).
http://www.newegg.com/Product/Product.aspx?Item=N82E16824014270
Or you can get an IPS panel monitor, which will get you far better colour reproduction. This unit has a fairly good deal running on it right now.
http://www.newegg.com/Product/Product.aspx?Item=N82E16824236287
Or if you don't have the budget, just go with whatever TN panel 24" has a brand name you trust printed on it. The quality difference between TN panels of reputable companies isnt really that noticeable.
