Question Which Motherboard and power supply to add
Xeneth10
Commendable
Apr 16, 2019
8
Hi guys,
Im building my pc for running games, 3d programs for design, and other programs for generating 3d models from photographs. I thought to buy this components but im missing the motherboard and power supply.
These are the components:
I'll add a hdd also and maybe expand the ram in a future. I wonder if u can help me with the missing components or maybe with some suggestion!
Thanks
pd: budget its 750 usd aprox for all of these plus case.
Eximo
Ambassador
Upgraded the memory to DDR4-3000. Ryzen likes fast memory, it sets the speed at which the CCX clusters communicate. Basically the CPU is made of two CPU modules.
Not much reason to get the R5-2600X over the R5-2600, though, you could save about $15 that way. A simple BIOS change away from being as fast.
Added an adequate case. I would like to see one more fan, but since this is relatively light, you can just move one of the fron fans to the rear. Or look at a slightly more expensive case to your tastes.
Or plenty enough budget to add in your hard drive if you take the R5-2600.
CPU: AMD - Ryzen 5 2600X 3.6 GHz 6-Core Processor ($179.99 @ Amazon)
Motherboard: ASRock - B450 Pro4 ATX AM4 Motherboard ($88.66 @ Newegg)
Memory: Corsair - Vengeance LPX 16 GB (2 x 8 GB) DDR4-3000 Memory ($87.99 @ Amazon)
Storage: Kingston - A400 480 GB 2.5" Solid State Drive ($49.99 @ Amazon)
Video Card: Zotac - GeForce GTX 1660 6 GB GAMING Video Card ($219.99 @ Amazon)
Case: Fractal Design - Focus G (Black) ATX Mid Tower Case ($53.24 @ Amazon)
Power Supply: SeaSonic - FOCUS Plus Gold 550 W 80+ Gold Certified Fully-Modular ATX Power Supply ($50.98 @ Newegg)
Total: $730.84
Generated by PCPartPicker 2019-04-17 11:08 EDT-0400
VADemon
29
6
10,545
2600X has a better stock cooler (Wraith Spire > Wraith Stealth) than the 2600. All you need to do so it auto-overclocks even better is to offset the CPU core voltage by a little (-50mV should work without thinking).
✔ for Eximo's list. (keep in mind 480GB will be barely enough just for a game library)
