[SOLVED] Which motherboard is best and cheapest for Ryzen 5 3400G?
Vaibhav_Rai@
51
keeping in mind that I will be overclocking my CPU and Adding a GPU in future. I want my PC to be as cheap as possible.
https://pcpartpicker.com/products/motherboard/#c=133&sort=price&page=1
There you go...that's one list. Just go as cheap as you feel comfortable; I'd go no cheaper than Asrock's B450 PRo-4 F or MSI's B450 Pro-VDH MAX myself. They all allow "overclocking" to varying degrees, however pointless it may be on most Ryzen CPU's.
Yes, B550 would be 'better' but you wanted 'cheapest possible' and, with a BIOS update, most B450 will support even Ryzen 5000 processors.
Vaibhav_Rai@
51
Thanks a lot👍, but why you said it would be pointless to overclock amd CPUs.
