Which motherboard would be better for my build?
Rifter89
27
I'm building my first computer and wasn't sure which motherboard to get, im not going to overclock or anything so idk if i really need the more expensive board
GIGABYTE GA-B85M-D3H
http://www.newegg.com/Product/Product.aspx?Item=N82E16813128607
OR
MSI H81M-E33
http://www.newegg.com/Product/Product.aspx?Item=N82E16813130730
Heres my build:
GPU: EVGA GTX 650 Ti 2GB
http://www.newegg.com/Product/Product.aspx?Item=N82E16814130840
CPU: Intel i3-4130 Dual Core
RAM: G.SKILL Ripjaws X Series 8GB (2 x 4GB) DDR3 1600
http://www.newegg.com/Product/Product.aspx?Item=N82E16820231445
PSU: CORSAIR CXM series CX430M 430W
Case: Rosewill Challenger
here is a side-by-side comparison between the two motherboards you have listed:
http://www.newegg.com/Product/Productcompare.aspx?Submit=ENE&N=100006519%2050001312%2040000280%20600462813&IsNodeId=1&Manufactory=1312&bop=And&CompareItemList=280%7C13%2D128%2D607%5E13%2D128%2D607%2DTS%2C13%2D130%2D730%5E13%2D130%2D730%2DTS&percm=13%2D130%2D730%3A%24%24%24%24%24%24%24
I'd go for the Gigabyte due to its having 4 memory slots and a PCIe x 16 version 3.0 slot. Alsthough it is more expensive, a much better board IMHO.
