Which of these cards would be a better upgrade for me (Radeon HD 7850 vs Radeon R9 270)
liamr
5
Currently using a Radeon HD 6670, and i have been looking at the R9 270 range but have also been looking into a Radeon HD 7850
Current spec's
CPU: AMD Athlon 750K X4@4.0Ghz
Ram: 16gb
GPU: Radeon HD 6670 2gb vram
Motherboard: Gigabyte F2A55M-DS2
Cards i have looked at so far
1. http://www.scan.co.uk/products/2gb-xfx-radeon-r9-270-boost-28nm-5600mhz-gddr5-gpu-900mhz-boost-925mhz-1280-streams-dp-dvi-hdmi-plus
2. http://www.scan.co.uk/products/2gb-msi-radeon-r9-270-gaming-2g-28nm-5600mhz-gddr5-gpu-900mhz-boost-975mhz-1280-streams-dp-dvi-hdmi
3. http://www.scan.co.uk/products/2gb-xfx-radeon-hd-7850-core-edition-4800mhz-gddr5-28nm-gpu-860mhz-1024-cores-dvi-hdmi-mdp-plusfree-g
4. http://www.scan.co.uk/products/1gb-msi-radeon-hd-7850-4800mhz-gddr5-28nm-gpu-860mhz-1024-cores-hdmi-2x-mdp-dl-dvi-i
5. http://www.scan.co.uk/products/2gb-msi-radeon-r9-270-gaming-28nm-5600mhz-gddr5-gpu900mhz-boost-975mhz-plus-bf4-game
Things to note:
-I'm a gamer and recently bought this PC, i knew it would need an upgrade so i would like the upgrade to last a few years
-My budget is around about £150, i would prefer less but i might be able to go a little higher if i have to
Thanks for the suggestion, it might be just a little too out of my price range i'm afraid. thanks for the suggestion though
