Question Which of these systems will not stutter?
smalltech
651
5
18,995
Hello,
I have listed 3 laptops below, assuming I am using for all these same task concurrently at the 3 laptops: 1 chrome browser open 100 tabs, 1 ms word, 1 ms excel, 1 pdf, 1 media player, 1 zoom, 1 notepad (I would need to switch between these programs often)
Q1. Would laptop A have more stutters/freezes than laptop B and laptop C? If yes, is it because laptop A has lesser ram?
Q2. Which laptop would have least stutters/freezes?
Q3. Which laptop would have most stutters/freezes?
Q4. Assume all 3 laptops are the same price, which laptop would you buy first? which laptop would you buy last? Why?
Thanks
LAPTOP A
ASUS Vivobook Go 14 | E1404FA-NK106W
14.0" Full HD 1920x1080 Display
AMD Ryzen™ 5 7520U Mobile Processor (4-core/8-thread, 4MB cache, up to 4.3 GHz max boost)
AMD Radeon™ Graphics
8GB LPDDR5
512GB M.2 NVMe™ PCIe® 3.0 SSD
720p HD camera with privacy shutter
Bluetooth 5.0 (Dual Band)
Mixed Black
Windows 11 Home (64-bit)
1 Year ASUS Warranty
1x USB 2.0 Type-A,
1x USB 3.2 (Gen 1) Type-A,
1x USB 3.2 (Gen 1) Type-C
1x HDMI
*Pre-installed McAfee Anti Virus + Backpack + Microsoft 365 Free Trial(30D) + Charging Adaptor
LAPTOP B
T490 Lenovo ThinkPad
Specs:
-14” Display
-Intel 8th Gen Core i5-8250U CPU
-16GB DDR4 RAM
-256GB NVMe SSD
-Intel UHD Graphics 620
-USB-C charging
-Windows 11 Pro 64bit + MS Office 2021 Pro + Adobe Acrobat Pro DC
LAPTOP C
L380 Lenovo ThinkPad
Specs:
-13.3” FHD IPS Anti-glare ( 1920x1080 ), Non-touch
-Intel Core Celeron 3965U CPU
-16GB DDR4 RAM
-128GB M.2 SSD
-Intel HD Graphics 610
-USB-C charging
100 tabs is impractical for any platform with 8GB of system ram. You'd need to look for something that can accept 32GB's of ram(either comes that way from the factory or you can upgrade to it).
4| I wouldn't buy either of them, not until I know what those 100 tabs are going through.
What sort of a budget do you have to work with? Where are you located? Preferred site for purchase? You're looking at yesteryears tech.
Moved thread from Systems section to Laptop General Discussion section.
