Which of WAV and WMA format is better sound quality?
bearearz
Hello,
Which of WAV and WMA format is better sound quality for coping/burning a CD? I'm a cancer patient and would love t record the best that I can in tearms of sound quality,(Least amount of compression? Thank you so much! TB
mibix19
Mp3 is a compressed format. I would suggest wave files as WMA is a windows sound format and not always compatible. Wave files will take up more hard disc space than MP3 as they are uncompressed. If you do use MP3 use the higher Bit Rates for recording
