[SOLVED] Which one of the cables of a power supply is for hard drive?
Diano
80
A power supply has 6 cables, one for 24pin motherboard, one for CPU, one for GPU, and three more. These three are confusing, one has a SATA power connector and a 4pin connector large and a 4pin connector small; another one, same length, has a SATA power connector and a 4pin connector large; and the third one, one inch shorter, has 2 SATA power connectors.
Which one of these three cables is for connecting SATA hard drive?
Thanks.
Q: Which one of these three cables is for connecting SATA hard drive?
A: has a SATA power connector and a 4pin connector large; and the third one, one inch shorter, has 2 SATA power connectors
Include an image of the cables you have to work with or the make and model of your PSU, if you're yet confused.
Lutfij
Diano
80
Thank you.
Very good teaching. Appreciate very much.
