which one will work better for CS-GO
PC_help
6
I was going to get a laptop but I want be able to play CS-GO on max settings our a little lower I have two laptops but I don't want to spend all my money on it if the cheaper one will run CS GO on max at 60fps that is the one I will get these are the one I wont
1 http://www.newegg.com/Product/Product.aspx?Item=N82E16834315131&nm_mc=AFC-C8Junction&cm_mmc=AFC-C8Junction-VigLink2-_-na-_-na-_-na&cm_sp=&AID=10446076&PID=3821802&SID=ikyt9808yz000a1700053
http://www.ebay.com/itm/Lenovo-IdeaPad-Y510p-15-6-1-TB-Intel-Core-i7-4th-Gen-2-4-GHz-8-GB-/281941983523?hash=item41a50d4123:g:xqoAAOSwuAVWyjE2
For $50 more, the Lenovo would be my recommendation. You will get better performance, the Acer would have problems running ultra settings at 1080p, I would expect far better performance from the Lenovo machine
thank you have a good day
