Which parts should i get for my Studio XPS 9100?
TehNinja
7
Hey everyone, I've finally decided to upgrade to the Radeon 7970, but since I have all stock parts, I know that almost everything else will need an upgrade.
Here is the GPU I would like
I know that I will need a new motherboard too, so i was thinking of this one
I will also need (according to AMD) a PSU of at least 500w, so i was considering this one
And to fit it all in, I wasn't too sure what to get for a case.
My current setup is:
Dell Studio XPS 9100
CPU: Intel i7 @3.20GHZ
GPU: Radeon HD 6450
PSU: N/A
Motherboard: N/A
RAM: 12GB
64Bit
Running Windows 7
Will the items i have listed all be compatible?
I know you all probably see hundreds of threads like these every day, but please help me out on this one. I've went to the local computer shops and they didn't want anything to do with me.
My budget is a solid $1500
Thanks for reading this, it means alot!
Why don't you build a new computer with all the parts? You can buy all parts within your budget. According to your specs I believe that you have a LGA 1366 X58 board with a first generation i7 processor. Your motherboard probably doesnot have a Sata 3 or USB 3 controller which is quite important these days. Also you have the old pcie x16 2.0 port.
I'm saying this because you can afford a new system with hd 7970
Motherboard
Gigabyte X79-UD5 http://www.newegg.com/Product/Product.aspx?Item=N82E16813128531 $280
Or
ASUS Sabertooth X79 $310
GPU
Gigabyte 7970 GHz Edition http://www.newegg.com/Product/Product.aspx?Item=N82E16814125439 $450
PSU
Cooler Master TX750 http://www.newegg.com/Product/Product.aspx?Item=N82E16817139006 $120
Or
SeaSonic X750 http://www.newegg.com/Product/Product.aspx?Item=N82E16817151087 $145
RAM
Patriot viper 3 http://www.newegg.com/Product/Product.aspx?Item=N82E16820220729 $100
HDD
WD Green 2TB http://www.newegg.com/Product/Product.aspx?Item=N82E16822136891 $110
Case
Tt http://www.newegg.com/Product/Product.aspx?Item=N82E16811133100 $100
Still you've got enough remaining for the processor. $320
If you wanna stick to your plan get the case and the PSU mentioned.
I would love to just buy a new system, but my parents bought me this system for christmas last year, and they're already kinda upset that I want to upgrade it.
I could probably get a better gaming laptop for half the price.
So would the parts i've listed in my original post work alright?
Thanks for the reply
You need an LGA1366 motherboard.
That powersupply is the BEST in its pricerange.
Youl enjoy that GPU.
GPU
PSU
Or
Case
It is better to get a higher power power supply for being on the safe side.
The case is out of stock now but it is a very good case and get it from somewhere else or when it becomes available.
If you are planning to buy a new motherboard get this
http://www.ebay.com/itm/Rampage-III-Extreme-FOR-ASUS-LGA-1366-Intel-X58-SATA-6Gb-s-USB-3-0-/261145394691?pt=Motherboards&hash=item3ccd7a7e03 $220
I love that case 😍
Thanks everyone, your da best!
