This basically takes my whole budget, I was wondering if there are better options I could take or anywhere that I could lower the overall cost. I do need an cd/dvd reader but i just put the cheapest one on without much looking into so what are your thoughts.
https://uk.pcpartpicker.com/list/xYjZXH
This is my first build so any info is helpful such as is the psu good if I was to overclock the cpu a little bit to maybe 4ghz? Also does the motherboard have good sound card or do i need a seperate one?
Also are there any extra case fans or anything that I should get? I am literally building from scratch with no other components being used so are there any other little things such as themal pasting, fans and stuff?
And last of all, what case would fit this all in? If possible one with a window you can see the inside of the computer
