Which PCIe x1 slot for audio interface?
tbecker76
12
Hello,
I own an Asus Sabertooth Z77, and want to add a MOTU audio interface. This interface consists of a PCI Express x1 card (MOTU PCIe-424), and an external rack for connections and analog-digital/digital-analog conversion (MOTU 24I/O).
Currently I have no PCI Express card installed, not even a video card (I'm using the integrated Intel HD Graphics 4000), but it is not impossible that I will add a video card in future.
My question is: does it make any difference, regarding the stability of audio streaming/processing, inside which PCIe x1 slot I mount the PCIe-424 card?
I would like to avoid "clicks" and "pops" (and any other malfunctioning), but perhaps these problems did occur only with old PCI (non-Express) cards?
If I understood correctly the different PCI Express devices, including USB ports, SATA ports, etc., share some IRQs.
Is it possible that when a device shares an IRQ with the PCI Express x1 slot, and that device requires a lot of resources, then the performance of the PCI Express card could decrease?
But probably the modern motherboards including the Asus Sabertooth Z77, are designed to avoid this...
Anyway again my main question: does it make any difference which PCI Express x1 slot I choose for the MOTU audio interface?
Thanks
It shouldn't matter, no. If for some odd reason there is a problem try a different slot (it's possible a given board might have a problem with one slot but that's more a fault in that board than a design issue)
Just to make sure that I explained correctly: are PCI Express x1 cards usually PCI Express version 2.0? I meant these 2.0.
EDIT: Sorry, I meant PCI Express x1 "slots".
Ah, well that isn't really relevant. PCIe 2.0 has been standard for quite a while in computer terms by now, after all.
To be more clear, if there is any competition for IRQ or resources between slots it shouldn't happen with an empty set of slots (that is, it shouldn't show up unless most or all slots were occupied)
I'm not sure if the PCIe-424 card is a PCI Express x1 v.1.0 card, or v.2.0 card. This time I mean "card", not "slot".
Does it make any difference regarding what you have written?
Thanks
So the situation is still the same: it doesn't make any difference which x1 slot I choose for this PCI Express x1 audio card.
Right?
