Which phone gs6 edge plus or note5
cjrinker1994
17
Getting a new phone Friday don't know weather to get note 5 or gs6 edge plus. I do like that the note 5 can have a defender series otterbox. But I also like the curved display on edge plus. They so like when it come to internal so just wanted to know what are your view. And ps don't come here telling me to get iPhone I do not like os operating system.
They are literally the same phones, with the exception of the stylus on the Note 5. The edges are so limited in use that they are essentially non-functional without root modifications. The only use I've found for the edges on my S6 Edge is the night clock--and that's only active up to 12 hours at a time. With the same hardware, it pretty much comes down to your personal taste preferences.
EDIT:
I stand corrected, it seems they are updating the edges to add a bit more functionality to them. I still think they're basically the same phones though. Just comes down to whether a stylus is something you'd use or not.
