Which power supply cables for ASUS X99 A II ?
msvisual
7
Hello, I am building a computer and I need to know which power supply cables is fine with my motherboard Asus X 99 A II. I have a Corsair CX 750 M with only 24 pin and 8 pin cables.
I checked in the Asus guide and it says to use 24 pin 8 pin and 4 pin,
Could anyone tell me wich cable I need to buy ?
Is my Power supply ok for this motherboard ?
thanks
M
Hi Zerk, yes is the green model .
I will change it .
Should I consider to buy another with 850 W instead ?
My configuration is
I7 6800k
Asus X99 A II
G Skills 64 gb ddr4
Noctua DH 15
Asus GTX 1070 8gb dual series
thanks a lot
Maria
1500 euro pc.... 30 euro psu.
the wattage level is meaningless, like your pc uses max around 400w?
it wont run better on a 2000w psu.
also bronze gold platinum etc is about efficiency, not about the voltage stability and or build quality.
if you eventually want 2 graphics cards, 750w is recommanded.
great: PCPartPicker part list / Price breakdown by merchant
Power Supply: SeaSonic S12G 550W 80+ Gold Certified ATX Power Supply ($64.99 @ Amazon)
Total: $64.99
Generated by PCPartPicker 2017-04-02 11:18 EDT-0400
best:PCPartPicker part list / Price breakdown by merchant
Power Supply: EVGA SuperNOVA G3 650W 80+ Gold Certified Fully-Modular ATX Power Supply ($98.99 @ SuperBiiz)
Total: $98.99
Generated by PCPartPicker 2017-04-02 11:19 EDT-0400
money aint an issue: PCPartPicker part list / Price breakdown by merchant
Power Supply: SeaSonic PRIME 650W 80+ Titanium Certified Fully-Modular ATX Power Supply ($139.99 @ SuperBiiz)
Total: $139.99
Only 1 power supply he listed has the proper power connectors get the one I listed.
750 Watts is a bit of overkill for your PC but that's not a bad thing it has the right connectors.
I might learn something new right now, which cables am i missing?
Yes it comes with 2 X 8 pin CPU cables both are 4+4 so you can split them in half for the 8 pin and 4 pin the board takes.
EPS (CPU) 2x 8pin (4+4)
The G2 L has a LED light at the connectors the regular G2 don't.
http://www.evga.com/articles/01050/evga-850-750-g2l-power-supplies/
The Board takes a 8 and a 4 pin for the CPU.
Is the EVGA SuperNOVA 750 G2L also good for my Graphic Card Asus Gtx 1070 8gb Dual ?
I need to connect the graphic card to the power supply.. is this cable in the kit too?
Or I need to buy another cable ?
Thanks
M
