bnn :
get a quality psu from a reliable brand like corsair, seasonic, antec. low quality psu's can fuck up your entire system if something happens, a psu is something you cannot afford to go cheap on, it is what is keeping your pc alive afterall.
recommending this, if you plan on upgrading your system (newer gpu's use a lot more power) in the future get the 750W version instead.
http://www.newegg.com/Product/Product.aspx?Item=N82E16817139031
I understand that, that is an expensive PSU for my budget. Do you think I can get away with this "PSU Power Supply Evo Labs Cronus Modular 650 Watt 650W 80+ Certified PC "?
These are the details, if you're interested:
Evo Labs is Proud to announce the launch of its new Ultra-silent Cronus Series, which is both 80 bronze certified and contains an ultra-silent "Fluid Dynamic Bearing" (FDB) fan as its major cooling component. FDB fans offer better airflow, allowing for better ventilation. The average FDB fan has a long lifespan (100K hrs), whilst staying virtually silent for years to come, The PSU comes with a 2 year warranty.
Key Features:
Power
650W
Input Voltage
100-240 VAC
Input Current
13A at 115V, 6.5A at 240V
Input Frequency Range
60/50Hz
PFC
Active PFC (.99)
Power Good Signal
100-500 ms
Hold Up Time
17ms
Efficiency
82%
MTBF
100,000 Hours
Protection
OVP / UVP/ OTP / OCP/ OLP/ OPP/ SCP
Dimensions
158mm x 86mm x 150mm (W x H x D)
Operation Temperature
0-45c
Safety
CE / FCC / UL / TUV
Cooling
140mm Fluid Dynamic Bearing fan
Noise
21 dBA
80 Plus Certified
Yes - 80 Plus Bronze
Certification
nVidia SLi Certified
ATi Crossfire Certified
Connections
1 x 20+4 Pin Main Connectors
1 x 4+4 Pin 12V Connectors
6 x SATA Connectors (modular)
4 x 4-Pin Molex Connectors (modular)
2 x 6+2 Pin PCI-e Connectors (modular)
1 x Floppy Drive Connectors (modular)
More Information
Support - Compliance with newest Intel standards ATX 12V, V2.2, V2.91, EPS12V
Efficiency - 85% at typical
MTBF 100,000 hrs
Cooling System - Smart brand new 140cm Fluid Dynamic Bearing (FDB) Fan with intelligent Fan Control (800RPM ~1500RPM)
Protection - Over Voltage Protection (OVP), Under Voltage Protection (UVP), Over Power Protection (OPP), Over Temperature Protection (OTP) & Short Circuit Protection (SCP)
Stand-by mode consumption 1W meets U.S.A Energy Standards/ EuP(Energy-using Products) instructions.
Smart Modularized Cable Management for better airflow by reducing cable clutter within built system & increasing heat removal
Key Components - The Cronus uses Taiwanese-Manufactured Major Components for better quality and steady electrical support.
Double EMI Filter for electromagnetic protection
80 Plus Bronze Certified
80 Plus Bronze
The Cronus series has been awarded the 80+ Bronze certificate across the range, and is also ERP Lot6 ready (+5VSB consumption 1W). The single +12V rail on the Cronus Series allows the use of high end graphics cards, whilst giving greater stability to your PC.
