I am building a new PC and below specs are for my older build that I want to put together again.
Specs:
I have a brand new EVGA 500W and an old EVGA 850W that is used for 8 years. .... I guess we have to cross out the 850W because it has 8 years on it and it could fail.(5 years warranty)
I did the online calculators, some say I need below 500W some say above 500W ....
Now PSUs are kind of cheap these days, do you recommend buying a higher wattage brand new PSU ? if so, what wattage ? is 650W enough ?
or should I just use the 500W one ?
Specs:
- i7-7700K OC to 4.8GHZ
- Gigabyte GTX 1080 G1 Gaming - some OC
- GA-Z170X-Gaming 3
- 2x16GB 3200MHZ DDR4 - some OC
- 2x 2.5" SATA SSD
- 2x M.2 NVMe SSD
- 8x 120mm cooling fans (CPU+CASE)
