Which RAID for Rendering, Performance and transfer speed?
Jacob_72
53
I am building a post production video and audio editing system and want the best RAID for rendering, RAID 0, 5, or 10?
CPU: Intel Core i7-5820K 3.3GHz 6-Core Processor ($319.99 @ Micro Center)
CPU Cooler: Corsair H60 54.0 CFM Liquid CPU Cooler ($59.99 @ Newegg)
Motherboard: ASRock X99 Extreme4 ATX LGA2011-3 Motherboard ($142.98 @ Newegg)
Memory: Crucial 16GB (2 x 8GB) DDR4-2133 Memory ($83.99 @ SuperBiiz)
Storage: Team Ultra L5 120GB 2.5" Solid State Drive ($39.99 @ Newegg)
Storage: Hitachi Deskstar NAS 4TB 3.5" 7200RPM Internal Hard Drive ($169.89 @ OutletPC)
Video Card: EVGA GeForce GTX 960 4GB SuperSC ACX 2.0+ Video Card ($199.99 @ Micro Center)
Case: Fractal Design Define R5 Blackout Edition ATX Mid Tower Case ($108.99 @ SuperBiiz)
Power Supply: Ultra X4 Special Edition 850W 80+ Bronze Certified Fully-Modular ATX Power Supply
Total: $1635.48
Generated by PCPartPicker 2015-12-05 18:39 EST-0500
You will get the best performance out of Raid 0 but you wont have any redundancy.
if you are looking for redundancy raid 5 will be best as in regards to performance.
Also looking into your build you dont have a storage controller, if you are going to be making a software raid i would just say dont make a raid at all if you are wanting performance but that also falls back if you are wanting redundancy or not.
What is a storage controller, The Raid is for working on my projects I plan to back up at end of night to carbonite until I can get a 12TB Raid storage system that is separate from my build.http://www.bhphotovideo.com/c/search?=WD+My+Book+Pro+12TB+%282+x+6TB%29+Two-Bay+Thunderbolt+2+RAID+Array&N=11148572&InitialSearch=yes&sts=pi
Storage controller/raid controller is a device your system would have to manage your raid and all of your hard drives connect to it, getting PCI bus speeds and some controllers have cache which will increase performance.
if a system doesnt have a raid controller (physical card) usually its a software raid which will actually decrease performance as data has to go through software then to your hard drive , just to give you an idea the difference between them.
if you are using the raid to back up your data that you dont want to loose, i would say have a raid for redundancy and dont worry about performance.
when you get your storage system and you want redundancy then go for the raid 1, you will loose half your space but if a hard drive fails you should still have access to your data.
Hope this helps man, best of luck.
