Which RGB Fans are best to use on a water-cooling radiator
Mortem420
128
Im looking to set up an RGB build, something that can be fully synced with either Asus Aura Sync or Gigabyte RGB Fusion. I know that this requires either a mostly Asus or mostly Gigabyte build which I'm ok with doing as I have the parts for both such builds picked out already, so now im just having trouble choosing RGB fans.
The build will consist of 2 120mm fans (for radiator) and 7 140mm fans for the top,front and back of the case.
Any advice for this would be much appreciated
