Which should I go for? 1440 or 1080 monitor ? and how much hertz?
hoks1984
GTX 1060 6GB
i5 7500
16GB ram 2x8 GB
Some of the games I play are heavy on requirements while others (majority) are light.
The 1060 should be able to give you "ultra" settings on all your games on 1080p while maintaining > 60 fps
There should be some games it will not be able to maintain > 60 for on 1440p
If you play twitch shooters (or the like); get a 1080p with G-synch monitor as you want all the fps you can squeeze out of it
If you play Civilization (or something where high fps won't give you a tangeable advantage/noticeable stutter); get a 1440p and don't worry about 120 Hz or G-synch
If you are willing to accept playing on non-ultra settings then the 1060 can do >60 fps on medium on 1440p for pretty much everything I guess.
And there is a whole bunch of ground between those options.
If you want more advise you'll have to specify what it is you play...
If you want more advise you'll have to specify what it is you play exactly.
Oh sorry about that I forgot to give examples.
When I say light games I talk about Gmod and such.
Heavy like GTA and Witcher.
Thx for help.
Latest posts
