Which side will the cabinet fan face
avi_in_lamborghini
44
Hello,
I have purchased a Cooler Master BC 80mm LED fan and installed it in the side of the CPU Cabinet.
But I'm not sure which side the fan should face.
Whether the air will blow in or the air will come out..
Currently, the air is blowing inside the CPU.
Is this OK..???
Thank You
If you look at the fan body, there are four legs supporting the motor in the middle, the side that these legs are on is the side that will blow on you if its facing you,
for a sidefan you want those at the inside as you have it now, so the air gets pulled into the case,
its fine as it is, no need to change it
Moto
Moto
