Hi,
I'm looking at upgrading my gtx 650 gpu to Gtx 760 4gb oc, I've 2 problems.
1. I'm not sure if my Thermaltake 500nl2l 500w power supply is up to the job.
2. My Z87m g43 mb has only one pcie 3 slot and one pcie 2 slot problem is if I use the pcie3 the gpu will cover the little pcie2 slot I need for my FireWire card which also requires a 4 pin power connector.
So will the gtx 760 be ok below the FireWire card in a pcie2 slot and is my power supply gonna handle it?
Thanks
Thanks
