which speaker will be best for me
Anurag_19
i have decided to go for f&d 510 and f&d 520and philips mms4040f ...i want full bass effect..which should i buy?
All three have the same amount of power in the bass but both F&Ds have larger woofers so it's likely that they will produce more bass than the Philips. Whether the quality of bass and the overall sound is better is a different story. No real way to tell unless you can listen to them next to each other.
